cel 24 on a 90?
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
im getting cels 22,24,51...i no my temp sensor is bad it wont give me a reading,51 prob a bad tps..but a 24 on a 90? when i checked the manual,motor,and sm i dont see a iat sensor,at least not before i went speed density..but i got that code before the maft pro?
any ideas?
dbsupra90
toonar
indiucky
it is inside the afm.
if you have that code since the mpro install, that is typical. you need to put a 1.2k resistor between THA and E2.
here is the pinout on my website if you dont have it. THA should be a light green colored wire and E2 is brown.
http://www.mk3.us/dave/tech/supradiag89.jpg
51 is tps, probably dont have it adjusted right.
dbsupra90
toonar
indiucky
i used a 1/2W resistor. direction doesnt matter, its NP.
the tps itself wouldnt cause that issue. but if it is far enough off that the mpro isnt going into the high throttle map, its possible maybe. but only b/c of tuning. i hope that makes sense.
it would be real helpful if i could see your bin file and a log.
