Just a few quick questions i couldnt find answers on while searching. First, Whats a good size to run off the valve covers? Would going to a larger hose off the vavle covers help with crankcase pressures? I know this would result in drilling and taping the valve covers to increase size.
Also, for running the outlet from the catchcan into the accordian hose, should one stick with the same size hose as the inlets? or run a larger hose?
I was planning to run a hose big enough so i can clamp it onto the original nipple on the accordian hose where the hose from the valve covers used to run...
Thanks,
Thanks,
