Carrier bearing or 1-piece driveshaft?
Status
Not open for further replies.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
tsupranami;1713471 said:
OK I'm done.
The baseless paranoid 1pc bashing can continue now. Or, start calling me names...whichever makes you feel smarter.
P.S.
No one here knows me either. No one has any idea what engineering background I come from, nor my racing (crashing) or vehicle history. I have refrained from calling people stupid or referring to their comments as stupid or idiotic, because I believe everyone here has a valid point when taken in the correct context. Comments aren't stupid or idiotic. They are comments. You might not agree, or you might have evidence to the contrary, and you should say so if so. But insults and demeaning labels are the tools of the weak, insecure, and incompetent, and should be avoided if your comment is to have merit.
Your input is appreciated trust me. Im glad there is someone with some knowledge stepping in and supporting their point of view instead of simply taking the word of a select few members. To make an educated decision one needs to know multiple views on something and you have pointed out some good arguments. I also appreciate the fact that you really are simply trying to provide an argument for discussion rather than just trying to make yourself seem smart or something to that extent which I tend to see a lot on these boards.
destrux
1,183
10
PA
I rebuilt my whole stock driveshaft, joints, bearing and all and had it professionally rebalanced for $190.
Those stock joints are a PAIN to remove if you don't follow the TSRM instructions though. I tried doing them the way I do domestic joints and it wasn't happening. Got the puller set out and it was a piece of cake.
What do cars like the new mustangs/challenger/camaro/CTS have? I haven't been under any of them yet.
Agree 100%, I stated what I did for my car based on my driving style after crunching the numbers, NOT on what a bunch of guys on a forum said, I don't expect anyone to blindly follow what I say without taking a little time to do some basic research into the subject.
When I first came into the Supra world I stupidly followed what then was the "common knowledge" on a few subjects and was confused when I lost a few engines, I went back to what I knew worked on other engines based on previous experience and no longer had the failures...
To explain for some of the guys that may not know "Why" DS's can fail universal joints don't rotate in a 360 degree circle it's more a figure 8 (CV Joints are an effort to reduce/eliminate this effect and a lot of modern cars use them in the DS's), eventually if you spin the fast enough you'll get shaft whip, long/smaller diameter the worse this gets until failure, different materials have different failure points (critical speed).
There are a few online critical speed calculators around and it's worth the effort to use them for peace of mind if you decide to go non standard or have a realistic expectation of your car spending time at high speeds, mine came about with the combination of a very deep OD ratio in the Tremec Trans combined with 4.3:1 diff gears and an 8300 rpm redline.
Oct 11, 2005
3,819
21
Thousand Oaks, CA
Why 1 pieces DS are not an engineering win.
Nc = K sqrt(E*I/m) / L^2
Nc = critical speed (rev/s )
K = constant typ between 1 and 4
m = shaft Mass
L = Length of shaft
E = Young's Modulus
I = Second Moment of Area
The problem is obvious, the non-linear relationship to shaft length is a real killer.
If you fix Nc, which is what you want to do since we want to avoid the Cressida problem, then since Nc is proportional to one over the length squared, if you make the shaft longer you need to dramatically increase the strength of the shaft to keep Nc constant. To make matters worse, the restoring force is a square root of the shaft material properties.
Example, doubling the length (i.e. going from 2-piece to 1-piece) means you need to make the shaft 16 times stronger to compensate, but unless you plan to switch to exotic materials, then your only solution is a bigger diameter and thicker wall thickness and that adds a lot more weight and results in a shaft that is heavier and hence has more inertia than the sum of the two shafts in a 2-piece. You never want to be on the wrong end of a nonlinear equation!
The loss argument is specious. The losses in a driveshaft are essentially negligible compared to the rest of the drivetrain. I mean its obvious right, if they weren't these things would be glowing red hot and be enclosed in cooling oil. Well, they don't and the carrier bearing in a 2 piece has negligible friction as well.
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
Now that's the beginings of some really useful information! $190 is an affordable rebuild in my book! Where did you have that done, and what parts did you get replaced? Were OEM parts used, or aftermarket?
I would love to rebuild my old shaft (again) but the shop I used boogered it up the first time, so I went 1pcr until I could find a better solution (shop).
Any additional info you could provide would be greatly appreciated...Thanks...
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
m = shaft Mass
L = Length of shaft
E = Young's Modulus
zombie;1713665 said:
you can't go bringing real math into this, this is supposed to be a mythbusters style way of saying why one is better than the other :p
Mathematics are fine on paper, and hypothesis are fine in a classroom, but where the rubber meets the road, where first place gets paid and everyone elso goes home; at the dyno, or at the dragstrip, or in many, many other forms of motorsports throuoghout history, and currently, the 1pc. wins.
If drag and friction were not a consideration, why don't we have toothpick-thin 3, 4, or 12 piece driveshafts supported by multiple bearings?
Do you consider aluminum alloys and the carbon fiber on some folks hoods to be "exotic".
If budget wasn't a consideration, we would all have torque-tubes or be on some Ferrarri Forum.
But when considering all the variables in the equation (including budget), there are tradeoffs that have to be made.
Braking is a nonlinear equation. Brakes are part of a safety system. Driveshafts are part of a propulsion system.
When the real-world Budget variable is introduced into the equation, I use the money saved on my propulsion system to advance my safety systems so that I am not on the wrong side of a nonlinear equation. The hundred dollars I saved on the 1pcr went to replacing the 20yr old rubber brake lines with new SS braided lines.
If I lose on the nonlinear propulsion side, I simply lose propulsion and have to walk home.
If I lose on the nonlinear braking (safety) side, I might never walk again. So do you know which nonlinear equation I have the most respect for?
Where are your priorities?
The money I save by not overbuilding or overspending on a 2pc build or rebuild I can put towards better braking, suspension, and steering systems, including wheels and tires. These, and many other components in the safety side of the nonlinear equations common to automobiles are far more important to me than losing a part of the propulsion system.
FWIW, the transmission tunnel in a unibody car carries a major portion of the chassis load, and is built like a brick sh*thouse. The chances of a lightweight driveshaft of any type of construction penetrating it are between nil to none.
tsupranami;1713964 said:
That's all I'm seeing. You were proven wrong without a shadow of a doubt. You talk about being an engineer, but then decide numbers don't work...
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
Variables. I guess you don't work with those, do you? I live and work in the real world. I use real world proofs applied to mathematical equations to modify variables as the evidence presents itself along the course of the experiment.
If it makes you feel better or smarter, you are right that with a simplified equation that overlooks or misjudges one or more variables, you can produce any result you want during a calculation.
With mathematical equations, I can show you exactly why bumblebees can't fly.
And yet, the real world will fly up your arse and sting you if you oversimplify the variables.
Calculate that into your substituted reality.
---------- Post added at 10:49 PM ---------- Previous post was at 10:40 PM ----------
Thanks IJ. I sincerely appreciate you giving us the particulars in your case so that others can use your experiences to their benefit. You are a gentelman and a scholar, and I appreciate all you do for us all on this forum. Thanks again.
For starters, the substituted reality is yours (nice strawman). Engineering is about the numbers. Or do computer models work off of magic? Even better, you apparently don't understand how the equation works and that the variables are known.
Also, a bee flys because it produces lift on the forward and back stroke. It makes perfect sense.
tsupranami
Drain Bamaged
Mar 11, 2006
134
Eastern WA
We didn't know that until the first models failed and we used real-world experiements with "magic" ( a new technology: super-slow-motion video) to introduce and verify the new variable (lift on backstroke).
It always makes perfect sense in hindsight.
Status
