car wont start??
ill cuhz
46
Bay Area
veedubin;1869759 said:
Agreed. My personal plan of attack for this would be:
Check batt. Voltage
Remove both batt. Terminals and clean them very well.
Trace negative from batt to body. Remove and clean.
Trace negative from body to block. Remove and clean.
Trace positive from batt to starter. Remove and clean.
Trace positive from batt to fuse block underhood. Verify the fusible link and the alt fuse are intact and no corrosion on connections.
Check/clean ground connection at intake manifold.
After all that, try to start it. A load test on the batt is a great idea too, if you have the tester. May also, for good measure, put the batt on a trickle charger while cleaning and inspecting you'd wires.
I've had this exact same issue and solved it by replacing the connection from the batt + to the fuse box.
GL!
Sent from my LG-P504 using Tapatalk 2
right on thanks ill give it a try then. thanks and btw, it jus weird because the only thing that fades away when i try to start it was the clock time. jus seemed odd to me
8,898
satx88supra;1869502 said:
Believe me
No thanks.
IndigoMKII;1869750 said:
Uh? You can disconnect that while the car is running and she will keep running..
Don't ever do that. You could end up on ebay after Toyota tells you how much they want for a PCM. Do you know how magnetism is related to the alternator? And what happens when the field collapses?
IndigoMKII
2,181
Madison, Virginia
Don't ever disconnect the water temp sensor gauge while the car is running?
