Hey guys, im new to the forum. Hopefully yall can steer me in the right direction. I have a 87 mkiii with a JDM 7mge with about 45,000 miles and Im having some problems. It kinda sounds like a ecu problem, but I need more input from other ppl.
Ive been dealing with this problem for the last year or so, so im ready to fix her. My car will not start when hot. Its hard to start when cold. It takes about 3 times to start. But when it gets warm after going to the store, when I go out to start it after sitting about 20 to 30 mins. It will not start. It will rev to about 1500 rpms then dies and I have to wait till it cool again to start it. It runs fine when hot, but after sitting for about 20 mins it will not start.
If I get it to start it will run like crap for about 4 miles then clears out.
Here a list of the things I checked and the new parts on it. Checked the TPS, MAF sensor, Air intake temp sensor, cold start injector timer switch and checked fuel pressure. Its at about 25 psi. I also checked the coolant sensor, and the pickup coils in the distrubutor. I replaced the FP relay, fuel pump, fuel filter, cap, rotor, wires, plugs, tps, o2 sensor, and air filter. I dont know whats wrong, but hopefully I can fix her. Let me know what you think. Im running out of parts to replace. thanks for the input. sorry the post is so long.
