UPDATE!!!
The car still hasn't started as of yet. My symptom now is, when cranking the engine, the injectors pulse twice then stop; indicating a loss (or no) Igf signal.
In the past two months, I've: replaced the igniter, repaired the engine wire harness, and also replaced the ECU with another known working ECU. At this point, one would think that this would eliminate all possibilities of loss if Igf signal; yet I still have the same symptoms. When cranking the engine, the injectors pulse twice then quit.
My engine codes are: code 22, and code 14.
Code 22 makes no sense, as I have a known working spare ECU temp sensor; and I plugged that in, and still get the same code. Since I rewired the harness myself, I know the wiring between the ECU temp sensor and the ECU are good. Guess I'll have to test the wiring just to be sure.
Code 14 once again points to loss of IGf signal, so I'm at my wits end on this one. Other than the igniter, wiring harness, and ECU, is there anything else that could prevent a loss of Igf?
