Car Wont Start, and mystery connector
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
87 Supra, replaced the burnt harness, replaced the broken cps, put in some cleaned/flow benched injectors, replaced the afm with a stock one, replaced ecu with known good working one.
Car will fire up on brake cleaner(just to see if it would start). But will not stay running.
Here is the connector that has no place for under the glovebox by the ecu.
Jumpered the efi relay #2 and #4 and no start.
Added a ground wire to the coils and still nothing.
Grounds under intake manifold are good.
Jumpered the fuel pump check in the diagnostic port and fuel pump kicks on
When you jumper check engine connectors the check engine light just blinks...
Where do i start?
Albert
May 13, 2009
1,710
Tempe, AZ
Nice, thats what I ment with the relay/resistor. Done that a couple times lol
