Well I posted a few days ago about another car running a TO4E and maftpro along with a million other mods it seems like, but just to make sure you guys dont get mixed up. I have an 1987 Turbo Supra. The motor is a JDM motor with low mileage on it as they all say. I got it built with ARP's througout, clevite 77's on the main,rod and thrust washers. Cometic 1.5mm HG. Radius valve job. Head machined with block and timing cover. Anyways I think that is enough on the motor. Well obviously as you can tell, as the title states. My car will not start. I am getting fuel, have 35 psi in the gauge that is on the fuel rail and when I crank it, it kind of smells like fuel > BUT I am getting spark, although not the strongest spark, when I crank it for a few seconds, i see the spark a few times. I set my timing according to the TSRM about a million times now. Also looked on jbl's homepage on the CPS alignment. So I have the main things done. BTW I have got code 41 - Throttle Position Sensor. Tomorrow I am going to swap one off of a running car. TB and TPS still attached and see if that clears anything up. Maybe my ignition timing is way off. I will be getting a timing light tomorrow and hitting it with that a go from there. Other than that..... Any help will be greatly appreciated? THX IN ADVANCE.......
