Car starts but doesn't rev up
90mkiiisupra400hp
169
Gardiner, Maine
I am really starting to lean towards the injector seals especially if you have no codes, sounds like the exact same thing my car was doing and if the PO removed the fuel rail at all then by the sounds of his mechanic skills I would almost bet he never payed attention to the grommets on the bottom of the injector, when I pulled my rail off I had 3 grommets that were in wrong and were leaking making the car idle but die every time I let off the throttle, I don't know but I would be sure to check them out.
NoLimitslja
61
Central FL.
I will definitely check this out any way to explain what is wrong and what is right?
Sent from my DROIDX using Tapatalk
supraguy@aol
Well-Known Member
Dec 30, 2005
4,277
66
Atlanta
Just run the car at idle, have someone hold the throttle if you need to, in order to keep it running at a constant rpm.
Spray carb cleaner using the included straw(for pinpoint accuracy), and spray a small amount towards each fuel injector, one at a time, to see if the dile changes.
If not, also spray slowly around the entire intake and throttle body, above and below, to check for gasket leaks.
Nghty89
Zombie Chicks Are Hot
Mar 26, 2008
978
7 Cities, VA
Supras are never easy... but are worth it. Tracing wiring gremlins tonight. Good luck!
NoLimitslja
61
Central FL.
Removed all cold side piping... Cleaned and replaced with same parts.. Cleaned turbo accordian pipe which I need to replace because this one has been hacked and modified and found that one of the hoses that connects from passenger side to driver side of the throttle body was crinkled almost to the point of closed and now the idle is great and there is a slight hesitation at initial throttle but it has stopped dying after revving... Now however I think I have an oil leak at the turbo which I will be hopefully addressing tomorrow and drive it some this weekend!
