Now i got the car to fire up but wont keep running.If i feather the gas it will run for about 30 secs but then sputters and shuts off. Could this be due to the lexus afm being installed without the injectors? What is the next step here?
Nomad707;877422 said:USE STOCK AFM!! YOU WILL KILL YOUR ENGINE!!!!!!!!!!!!!
jdub;877982 said:NO...do NOT do that! I wanted to be sure you didn't...it's the #1 killer of the electronics.
It still sounds like you have a timing issue...is your CPS set like this with the crank pointing at zero and the cam gear index's pointing up at the marks on the gear back plate. (Sure are a lot of timing issues lately)
Check all your connections too...coil packs, plug wires, AFM, CPS, etc.
http://img2.putfile.com/thumb/8/23318563877.jpg
