Car overheated this morning...
Status
Not open for further replies.
jdub
Feb 10, 2006
10,730
Valley of the Sun
It doesn't cost as much as a Fluidyne or PWR, but it's not cheap either...~$300. It's a full aluminum race radiator, dual core and it drops right in...I've got one and really like it. Saved my bacon a couple of times...including when my thermostat stuck ;)
BTW...compare the Stant thermostat with the Toyota one...if I'm not mistaken, the outlet hole is a smaller diameter. Got the one I'm running now at AutoZone...basically identical to OEM.
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Yeah, I thought the CSF was the cheaper one, I've been looking at them recently. Hopefully by the end of the month, I'll have enough for one.
Yeah, the stant is a different shape, and size I believe, I was running one before the toyota oem one and it was okay, it at least opened...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Well, I can assue you if your radiator is clogged along the bottom, it's a major contributer to your problem. I'd get the coolant system pressure tested. Check your oil cap for milky oil just in case.
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
Oil is fine and has been,
I've already been through all this and worried far too much about BHG,
I know it's the radiator
jdub
Feb 10, 2006
10,730
Valley of the Sun
I think it's your radiator too ;)
Just checkin man...I'm not one of those guys that jumps on the BHG wagon right off.
A pressure test might be a good idea anyway...it will reveal any other little leaks in the system that might be letting air in.
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
haha yeah,
I love all of them
ya know, they're so helpful with their "you have a BHG, you are screwed" posts:biglaugh:
Any idea how mucha pressurer tester would cost?
JENNY!
Supracute
Mar 29, 2006
224
Dublin, CA
yeah but mine was getting hot because the wire thinie that goes to the thermostat sometimes doesnt have a good connection so all i gotta do it twiddle with it a bit and its fixed.
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
The thermostat is a mechanical device that opens up at a certain temperature,
what does a wire have to do with it?
mattsplat72
is sofa king
Jan 17, 2006
1,738
kylefoto said:
Thanks dick!
haha.
Noticed you gave up and just went ahead and got the parts for the gasket swap for yours...
Yeah, oh well I just needed an excuse to spend money . I talked to my wife this morning and I am going to wait until maybe march to get it done . My current plan is to .:aigo:
Replace ALL gaskets
P&P HEAD
BC full set up w/264 cams
ARP blots (have)
MHG
Greddy timing belt
the group buy cam gears
All new coolant hoses and thermostat
intake and hard pipes
:evil2:
So what do you think ? Good start to get me to 400whp? let me know and we should hang out I miss boost the 06 altima is ok but not a supra
dav_dman
old guy
Oct 23, 2005
107
louisville KY/so.IN metro area
mine didn't overheat..just started pissing antifreeze when i pulled into the garage last night.. chk'd and nothing from rad or hoses but lots of dripping and water under the intake mani.. and bubbling... shit, i thought..bhg on an engine with maybe 2000 miles on it and arp bolts etc, stock boost;shit...got a mirror and it's just the hose from the idle control valve.
*whew*..
kylefoto
I am not ASIAN!
May 7, 2006
1,674
Lynnwood, WA
HellsLegion said:
The wire from the housing to the guage. Mine did it for a while too. It looses a connection and spasses out
gotcha
I just straight up replaced the stock gauge,
a
it wasn't working
b
they suck.
no electronics to deal with, just a temperature reader that plugs into the hole. So simple.
Status
