The car ran and started ok this morning, i drove it roughly 15 miles to have my brother help me with a few noises. After playing with the CPS,tps, and re-timing the car we decided to take it for a drive. Not after 50 feet the car just shut down, after rolling to a stop we started checking things. There is no power to the fuel pump, and there is no spark.(the pump is a walbro so its obvious when its not on). The fuel pump has the direct 12v mod done. The EFI fuse in the bay is good, along with the ECU-IGN fuse in the kick panel. The starter is working fine and cranking normally.We reset and played with both the TPS and CPS to try to get it to start. Nothing. Any help is welcome. Thank you.
