Car Hits Boost but doesnt Go...
Supra-Man18
357
miami
All Show no go... I step on it, the twins spool up 15 psi but the car doesnt Go like 15 psi.. It moves like less than stock actually. The car is not putting the power to floor i guess but what can it be.. My clutch isnt slipping.. (not noticably anyway).. I let my friend drive it n go into boost and i as a passenger am not getting sucked in my seat.. My 7M did That ! What can cause this ?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
timing could be being pulled back. Are there any codes present? Is the CEL coming on? Are the knock sensors properly wired? Is the IAT and CLT sensor properly working? Are the cam lobes flattened out?
What RPM does it spool by?
THE1JZSPECIAL
111
South Florida
supra-man18;1043080 said:
all Show No Go... I Step On It, The Twins Spool Up 15 Psi But The Car Doesnt Go Like 15 Psi.. It Moves Like Less Than Stock Actually. The Car Is Not Putting The Power To Floor I Guess But What Can It Be.. My Clutch Isnt Slipping.. (not Noticably Anyway).. I Let My Friend Drive It N Go Into Boost And I As A Passenger Am Not Getting Sucked In My Seat.. My 7m Did That ! What Can Cause This ?
What Is Your Setup?
Supra-Man18
357
miami
Alright.. the CEL is on, one of the codes is no knock sensor signal, before that motor was actually cranked the timing was off so it had to be set again, and what exactly is the IAT and CLT sensors ?
Supra-Man18
357
miami
THE1JZSPECIAL;1043089 said:
What Is Your Setup?
My set up is stock 1jz, stock downpipe, walbro fuel pump, afpr, 3inch cat back, and FMIC, 15psi on the stock twins... and the car goes no where ...
THE1JZSPECIAL
111
South Florida
if the computer is not reading a knock sensor signal it wont allow an advance in timimg which explains the no go, So the only code your getting is the knock sensor?
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Supra-Man18;1043080 said:
All Show no go... I step on it, the twins spool up 15 psi but the car doesnt Go like 15 psi.. It moves like less than stock actually. The car is not putting the power to floor i guess but what can it be.. My clutch isnt slipping.. (not noticably anyway).. I let my friend drive it n go into boost and i as a passenger am not getting sucked in my seat.. My 7M did That!What can cause this ?
What can cause this, you ask?
There ya go.
My 7M did that!
TORQUE.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Intake air temperature, and coolant temperature.
If you're throwing a knock code though, that's your problem right there. The ECU will pull timing because of it, losing you lots of power.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
soapra;1043148 said:
I got a 1jz here that can make torque, I have no idea what others outside of California do to lose torque, but we got a great amount here! LOL!
I just felt like bustin' somebody's chops, the only 1J I've been in sucked me into the seat pretty good... When the turbo spooled at least:biglaugh:
Win.
Supra-Man18
357
miami
Thank you much bro...
