CAR DOES WONT RUN FAST
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
Hello just need some expert advise,
I have a 90 toyota supra turbo. Engine is fine no leaks or what so ever.Turbo condition is unknown but does not smoke...and still turns..however when i drive running on 2nd and 3rd it would not go fast like it used too. Even when i floor the gas pedal it seems like i did not press not the gas. the RPM goes up slowly and even when i press on it hard..like u can feel that the pedal is pushed fully..Please help..anyone..
Thank You
Noremac
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
Now I can bet everone is gonna tell you to search but I just did a search on Boost leak and didnt find much info as to what it actually is...
Its when there is boost(the pressure your turbo makes) escaping from either a vacuum line or an Intercooler pipe. Basically check over your car for lose pipes or lines that have come off or been disconnected.
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
OK...I JUST CHECKED FOR BOOST LEAK..FOUND NOTHING..I CHECKED AIR PRESSURE FROM TURBO..ITS GOOD..
TurboFreak88 said:
They arent really needed unless your gaskets are messed up.
I mean it certiainly wouldnt hurt to replace them...
LordLo
242
OR
Maybe even your stock bypass valve may be dead. I raced an accord once with a bad bypass valve and would get beat all the time.
Put in a aftermarket BOV and he could no longer touch me. haha.
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
Bypass valve?where is that located?do you have a pic?soory dont know much bout surpras
Thanks
noremacsupra
beginner
Jan 29, 2007
85
Los Angeles
Under TRSM which one should i check?
Introduction ?
Maintenance ?
Engine Mechanical?
Exhaust System ?
Turbocharger System?
Emission Control Systems?
EFI System ?
Cooling System?
Lubrication System ?
Ignition System ?
Starting System ?
Charging System ?
Clutch ?
Manual Transmission?
Automatic Transmission?
Propeller Shaft ?
Front Axle & Suspension?
Rear Axle & Suspension ?
Brake System ?
Steering ?
SRS Airbag?
Body Electrical System?
Body ?
Air Conditioning System?
Service Specifications?
Standard Bolt Torque Specifications?
SST & SSM ?
Electrical Wiring Diagrams?
Thanks
Noremac25
Questions, comments, rude remarks contact webmaster.
er TSRM which ones shud i check?
MDCmotorsports said:
Heres how to make a home made boost leak tester:
http://www.vfaq.com/mods/ICtester.html
As for cps & cam timing, refer to your TSRM.
