Car died,what to do next!!! life story inside
Kckazdude
1,239
Memphis, TN
Enough of the SR20/240SX talk already! We are on a MK III Supra forum for krissakes! j/k :evil2: :icon_razz
That parts/donor car is an excellent find. Wish I could get one in similar fashion for my needs. Good luck with the near future build.
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
supradan22 said:
I would change and shim the oil pump along with new bearings and a MHG.
Good idea. will do,but never shimmed a oil pump. how it b dun? (yea i coulda typed it the correct way,but why??)
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
car doe's have 209k on the odo,newish t-belt.. wonder what else i should do befor dropping it in? i dont wanna go all out ,as i will be building the other engine for big numbers! but i will be throwin 550's ,lex and ,57 trim at it!
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
Squid699 said:
Progress report?
engine is out of both cars.harness is swapped to 5sp engine.installing pedals,and everything else needed for 5spd swap (lines and whatnot). hopefully droppin it in tomorow.driving it home wensday if all go well!
also have a turbo timer to install,safc-neo,and lex afm...60 trim in the mail.huntin 550's now!!! (and a fields harness) : )
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
Engine is sittin in the car.mostly everything hooked up top and bottom side.jus gotta put radiator,and hardpipes back on ,fill fluids,hook up electronics inside,.....and hope i have all wires connected when i try to start it!
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
got the car running today.drives ok,until you get to 45oo-5000rpm,kinda feels like it has no power,like somthin holding it back. no codes,but im sure i will be tryin to figure out what the problem is,also i stopped at the store on the way home,came back out and saw a puddle of coolant under the car
when i popped the hood i saw coolant dripping from the intake plenum,kinda in the middle of it...couldnt tell exactly what it was dripping from,but definatly dripping from plenum area.
no smoke,but crank seal is gone.has a steady drip frk there when car is running,gotta replace that also i guess...all in all still pulls a helluva lot harder than the auto.
so,i gotta fix all those things mentioned,and put my interior back together dash and whatnot is still pulled apart.car is pissin me off a little.has me thinking about selling it.....more than likely not,but possibly
