CAR CAUGHT ON FIRE!!!!!! please help asap
destrux
1,183
10
PA
The clutch line or slave cylinder wasn't leaking was it? Brake fluid is flammable (not easily like gas, but if it gets hot enough it will burn). If it was spraying on the hot clutch (possibly why it was slipping?) maybe that's what set the fire.
D.J.T.
877
Arkansas, United States
before doing anything to the transmission adjust your clutch pedal. I had just replaced mine with OEM dealership kit & it slipped bad at boosting levels, old man came adjusted the pedal, NO MORE SLIPPAGE. The pedal was way to tough, it smoothed out.
CT26smoker
223
Houston
IBoughtASupra;1683611 said:
I have the DriftMotion clutch line. It has a protective covering over it and stop it from shorting out.
LoL, not if the line is one of the stainless steel brad hoses......
the hose will carry currant from one end of the hose to the other.
It can, on an engine without a ground, carry currant from the slave cylinder to the firewall.
It doesn't have to touch anything.
