car bucks like a horse
88ttsupra
15
ruskin,fl
:1zhelp:eek:k well my name is jon and i own a 88 turbo supra it has hks super drager catback,2.5 inch hard pipe,blitz bov,greedy dual boost controller,and everything else is stock including down pipe. my problem is that the car wont stop bucking when i try to accelerate :aigo:any thoughts?
steven89
892
Houston, TX
88ttsupra;1226647 said:
evrything is replaced except theon right off the turbo but the clamp was tight
Id check the one off the turbo anyways. .Take it off and look at it. I had one that looked like it was good but had a small crack right where the clamp was.
88ttsupra
15
ruskin,fl
ok ill do that is it a small coupling or is it a 90 degree peice?
suprafanatic
1,607
Greenwood, IN
maybe it isn't fuel cut.. if its happening at 1psi..lol however, if he did have a leak like that i wouldnt think it would "buck" like he says it is. i'v had a leak many times and the car just has a lack of power
88ttsupra
15
ruskin,fl
Nope no shuddering... :/ Just bucking.. It goes then dies and then will go again then die.. and it keeps doing that.. Not a TPS either i already bought one and put it on and it didn't stop it..
GuNDeZZZ
Was dgilman360
Sep 28, 2006
619
Lakeland Florida
Bucking like the car is swaying front to back or just shaking during boost?
dumbo
1,911
Albera, Too Far North
i would check the hose off the turbo, it sees the most heat. how are you driving the car when this happens? does it due the same idleing/reving?
88ttsupra
15
ruskin,fl
Not idleing jus tryn to accelerate...
