Capacitor
bigaaron
4,692
Pomona, CA
www.driftmotion.com
edit: <removed rant>
Ok, without me getting all huffy, an Optima battery will help with lights dimming as much as a cap, plus it has a higher amp hour rating then a standard battery, plus it will not leak, plus it costs less then a good 1 farad cap.
Maybe your car audio system makes noise, but all I hear from mine is music bro!
born2drv
1,199
Burbank, CA
I don't remember how old my alternator and battery were at the time when I added the cap a while back. All I remember is it made a big difference cleaning the sound up... before it would sound very distorted, not engine noise or anything, just you could hear the amplifier was struggling to get enough power and would crap out at high output. After the cap was added that problem went away.
You could possibly get the same results by upgrading your battery and alterator first... (like I did recently), but I still say a cap can't hurt. (just my personal experience don't flame me please) ;)
1.21 GigaWatts Baby!
born2drv
1,199
Burbank, CA
glad i could help out ;)
btw - i got a pic of me next to the delorian from back to the future, i'm gonna try to find it :biglaugh:
Fuzz420
Are U Here 2 take My Baby
caps are a waste of money. Money is better off spent elsewhere like a h/o alternator and better battery(yellow/bluetop, stinger,kinetik)
It all depends on your goals if you just want something to help support a medium small amp to play, lets say some door speakers, then a cap is for you.
Now if your wanting all-out shove then a battery is for you.
Me personally i have run 2 12's on our factory alternator(im n/a 70amp) with an Orion2250 "the beast amp"(raw old school power) Thecurrent draw on this puppy is well in to the 300 amp range.I was advised to use 0/1 gauge but i used 4 gauge instead. Let me tell you i couldnt play jack hard with the stock battery with out watching the stock volt meter dip into the 9's!!!!!!!
I upgraded ONLY the battery, and my voltage would drop below 11.5volts(all readings from a stop while foot is on brake/ w accessories). In a highpower system i wont run optima, they lack relief valves so when they get hot they go boom.My kinetik does have relief valves and they badboy is a bad mamajamma. http://www.kinetikaudio.com/hc1400.asp the prices listed on the page is higher than what they retail for, but as they say quality comes with a price. Ive had mine for a year an 3months now and its still read 12.6 on my multimeter when cold!!!!
*with my setup as mentioned with a major air leak in my box, i mustered a 142.8 on the mic
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I'm afraid we're just going to have to agree to disagree, folks. I already have an upgraded battery and alternator, and the cap still made a huge difference. I rarely turn my system up anymore, it's a leftover from my foolish youth, but when it starts pulling upwards of 80 amps average, there were problems. I managed to pick up a 1 farad cap from a clearance house where they sell off goods from places that have gone tits up for pennies on the dollar, plunked that in, and no problems since.
PS: I rather dislike talking in watts, as every manufacturer spews total BS when it comes to power ratings - unless you are buying competition amps that have been bench tested and certified.
Fuzz420
well your case is slightly different considering you already have the battery and alt. Usually at this fork in the road, the majority of people at this stage opt for a secondary battery in the trunk.But im sure since all the priorities are correct in your system your capacitor is behaving how it should, supplying a constant voltage to the amp easing the load on the circuitry. I believe a lot of people dont understand u have to have at least the alt upgraded before the capacitor is acutually running efficiently, and not cause more harm than good, because the capacitor them selves is a huge load in the circuit
Turbo. Targa. Life.
SupraMania Shirt Slinger!
Apr 16, 2005
1,709
O'Fallon, MO
www.geocities.com
CEA certified power :)
Alpine amps have been doing SURPRISINGLY well with this. They all come with one of those "birth certificate"things from where it was tested, and they've been anywhere from 10-100 watts over advertised RMS power!!!
bluemax
The Family Man
Orange County, CA
Capacators act as high pass filters. So if you have a capacator with a low enough cross over point, it will stabalize the power to the amp better. Capacators are used in the speaker cross over (typically). Long time ago my brother had to use a capacator in the power line to his stereo because he had that buzzing noise in it. The amp itself has storage capacators for peak power.
So Grim, what difference did the capacator do in your stereo?
Check this site out:
http://www.bcae1.com/xoorder.htm
Turbo. Targa. Life.
Apr 16, 2005
1,709
O'Fallon, MO
www.geocities.com
What you have just stated is true, however most (read: most) amplifiers have high-pass filters built in; so as long as you've correctly set your HPF you should be all good without a cap.
That buzzing noise your brother had was because of incorrect grounding--it's alternator whine.
