Can't understand why my supra is tripping NEED HELP PLEASE
Prince
California
Ok, i recently bought a mkiii supra and on the way home the throttle engaged itself all the way. I shut the car off and coated to the side. I had to tow the car home and then i took a look to find that the tps was loose, and is missing a screw. I tightened the one screw i had and then turned on the car. Now the rpm jumps from 500-3000 over and over and over. What is the problem? any suggestions would be great, its been sitting outside for a week and its killing me that i cant drive it
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
How about taking it to a mechanic and having it repaired? This is obviously way above your skill set. You bought a 20 year old sports car off of someone without knowing the basics. Looks like you'll need to start learning quick or you'll be out major $$$ over your period of ownership. Wait until the real issues with these cars start veering their heads.
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
You should really add more information to your posts too i.e is it turbo or non turbo
There could be a few things but a good place to start is with supracentral's post, you'll need a set of feeler gauges and a multimeter to set the tps correctly, if this isn't set properly it will cause all hell of problems.
Also don't forget a supra owners best friend is self diagnostics http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=23
