So my wastegate doesn't seem to want to work with any controllers. I tried a manual and now my blitz EBC I hooked up. When it's hooked up, it will just go to 6 lbs no matter the settings of boost. I have a knock off external wastegate. I have everything hooked up correct, but it just won't hold any more.
I had the top vacuum port on the WG hooked up to the compressor to keep it closed to see if it will boost past 6, and it goes to 15 lbs easily.
Any suggestions? Just buy a good wastegate? I mean if it holds boost when I have just the top vacuum on, should it work when it's hooked up to a boost controller??
