Can you solve my boost mystery?
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
IJ.;1250055 said:
Funny
877m;1250051 said:
u can go onto hks.com and buy i feul cut difencer or fcd and that will stop u from hitting fc of u can get i lexus v8 afm and bigger injectors but i would go witht he fcd because it is only 100 bucks or so. also try unpluging your factory boost guage there is a plug when u open the hood on the passanger side and it goes to a little thing about the size of a nano ipod its 1/2 way between the front of the car and the fender it says boost something on it and that should let u get about 14 psi
Not funny.
I think we're done here. The car is fixed:biglaugh:
Bluechulappa
839
hOUSTON
www.houstonareasupras.com
gaboonviper85;1250091 said:
Pulling the pin on a grenade.....
Fuel cut is a wonderful fail safe
Indeed fuel cut is a very great fail safe. I knew I should be able to run stock boost even with exhaust and intake mods but people kept telling me otherwise.
No FCD for me! I will happily run 6psi for the break in of my new motor!
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
unplugging your factory boost gauge does not change the amount of boost the car runs. the factory boost sensor goes to the gauge in the car, not the ecu...
877m
65
Lewiston, NY
no it does not change the amount of boost it will run but i does change the feul cut by a few pounds cuz it does go threw the ecu it is not i manuel guage it is electronic when i unpluged mine a got 2 or 3 expra psi before i hit fuel cut
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
thats funny...it had no effect when unplugged on my car...
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Your ignorance is showing in a big way. This is the Tech Section. If you don't know what you're talking about don't post...
877m
65
Lewiston, NY
well i am a tech and i do work on quite a few supras including my own. and it wont make u run more boost it wull just make u not hit fc at the stock 11 pounds. and with these 7m motors boost makes a big differenc u get about 11 hp from each pound but u got to remember u got a 92 those have some slight changes from my 87.
JesseH
1,153
Englewood, Ohio, United States
also try using propper grammar...when you talk like your in high school people are going to treat you that way.
Bluechulappa
839
hOUSTON
LOL at the TECH!
877m
65
Lewiston, NY
Poodles;1255381 said:
Doesn't matter, the boost sensor is in no way connected to the ECU.
if it is not connected to the ecu then how would it hit f.c. also if it was not connected to the ecu then why when u put a tunable ecu in there u can change where it hit fuel cut it has to be connected to rad how much boost it has. now im not going to sit here and start a big argument because we are really all here to help each other but like for instance i was at about 12.5 psi or so i was at the point where i was jus hitting the f.c ad when i unpluged my boost sensor i didnt hit it any more. now say in your case u have your boost cranked up where its trying to run 16 or 17 psi yea your still going to slam the f.c but unpluging does give u a litlle help. of u could also get a new ecu or u can also get rid of f.c by getting a lexus v8 afm and bigger injectors.
JesseH
1,153
:sarcasm:
ok seriously... you need to do your homework before you post... Fuel cut is in no way determined by that. Fuel cut is controlled by the frequency of air that is being pulled into the AFM, Fuel cut is around 1500hz.... when you up to a lex air it takes more air for it to hit that frequeny therefore, higher fuel cut...same as when you install a FCD, it puts a "cap" on the freq. so it never sees that 1500hz, with that no fuel cut. With a stand alone, those limitations are not there and normally do not use a AFM anyway.
-Jesse
Please stop.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
877m;1255212 said:
well i am a tech and i do work on quite a few supras including my own.....
Wtf? What part of "if you don't know what you're talking about don't post" didn't you understand? I suggest you clam up before you look dumber than you already have. There are people here who've forgotten more about this car and how it works than you'll ever know.
jdub
Feb 10, 2006
10,730
Valley of the Sun
You are seriously making my head hurt...and, you seriously do not know what you're talking about. Fuel cut is in no way related to the boost gauge sensor...the volume of air through the AFM determines it.
All of this was previously stated. You do not have a clue on this issue...please stop posting in this thread and the Tech Section. Last warning.
Also use real English and grammar too...and, stop the text messaging BS.
877m
65
Lewiston, NY
x87SUPRA87x;1256583 said:
:sarcasm:
-Jesse
ok i get that but then why would it have stopped my fuel cut? and is a fcd jus a resistor? and also why when i read up on going with the lexs afm i was told i would need to upgrade my injectors or i would still hit fuel cut? cua i mean the 440s are not really small u should be able to run 18psi befor u lean out
JesseH
1,153
seriously though, you need to stop....what everyone is posting in response to you is taking away from the OP's question. If your not 100% sure that the info your posting is valid, please don't.
