Consume oil, yes, and if you drive your car hard that extra quart helps keep the oil pickup covered. Uncovered oil picku = rodknock.
The crank isn't even close to hitting the oil in the pan at that level, I've heard you could easily run 2 quarts over and still not have any issues.
Personally, I run the third gasket in the center instead of the "upgrade" to just the sealing rings for the oil galley plugs. Either way, water/oil in the plug valley WILL cause issues.
