I need to weld (or replace) the rear timing cover where the turbo's coolant line return goes. The previous owner ran a oil cooled only turbo and welded over the coolant return. I drilled and tapped it for an NPT fitting. The walls weren't as thick as I had thought and now there is a small hairline crack where the fitting was tapped.
It's easy enough to get to, but nobody I know has the correct equipment to weld aluminum, so I'd need to either have the car towed or removed the timing cover and bring it to someone. If I remember correctly, the rear timing cover was machined with the block and the head sits on it. So can the rear timing cover be removed and replaced without causing leaks, or do I have to have it repaired while it's still in the car? I'd really like to avoid using epoxy as it would only be a temporary fix and make a mess when it comes to getting it welded down the road. Plus it's only several inches from the exhaust manifold, so any epoxy won't last long.
Thanks.
Thanks.
