Can oil gauge/sensor be calibrated?
FloTex
Crankin since the 1900s
Aug 13, 2008
47
Tallahassee, Florida
My dash oil pressure gauge is reading about 15 lbs low with an OEM Toyota oil pressure sensor that is less than a year old. I checked it with a mechanical gauge after a rebuild.
I will check the gauge per the TRSM diagnostic spec. Other than replacing parts is there any calibration of the sensor or gauge?
FloTex
Aug 13, 2008
47
Thanks- there was some question about whether jetjock has ever posted anything about it but I couldn't find it.
I could bend the needle. Or rotate it on the bezel 15 psi. Or re-label the gauge face. Or add an amplifier to the circuit. :icon_razz
I haven't heard of many gauges failing so it's probably not the gauge. I'll check it. This is the second sensor. I'll check wiring and ground also.
