well i dont know where its coming from but i know water is leaking down from the back of the motor somewhere right on top of my transmission help please guys.. thanks.
The heater coolant feed line is at the back of the head and also has a big banjo fitting feeding coolant to a small 90 deg hose to the coolant hardline on the block exhaust side. It's either the heater feed hose where it connects to the fitting or the 90 deg hose. Either is bad and needs to be fixed ASAP...if it bursts, you lose ALL of your coolant in a very short time causing a massive overheat.
^Yup. It's kind of a pain to get to, but a cheap and easy fix. Mine exploded last year. Not fun, and kind of embarrassing, being as though I was racing at the time. It made it easier to get to by removing the charcoal can.
