Well, All I have to say is I don't know what I am doing. If I delete the old Catch can then what? Am I supposed to plug the old places that the lines went to?
Very cool! Polobai, the only question i have is where does the little clear hose on the side of the catch can lead. Also, I've been noticeing it goes into the valve covers and the hose that goes to the turbo. So what does a catch can do?
I never actually ended up putting the one-way valve to the intake pipe like what's pictured in the below diagram. As IJ had previously pointed out in another thread, it is not needed.
Depends on how much blow-bythe engine has. Which depends and many varables such as engine wear, including worn rings and seals. Also, I believe the more boost one pushes, the more blow-by the can expect. If your cc is filling up quickly, there are issues you need to address.
