Can i make a 7mge stock radiator work for the 1jz?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
I'm kinda broke right now while i'm working on my swap so could i make the 7mge radiator work for the 1jz? or do i have to get a different radiator and fan? if i do have to get a new radiator which ones do you guys recommend?
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Dunno about making the 7M work but I know DM sells a Koyo Racing rad that is a common swap purchase.
EDIT: http://www.supramania.com/forums/showthread.php?t=24799&highlight=7m+radiator+1jz Just searched, similar question. Instructions on second page for making a 7M rad work w/ fans and all.
sprite059
7
Dubbo Australia
The only real difference is that the JZA70 has a thread in the bottom for the temp switch for the hydro fan. They are also about 4mm wider so don't try to swap to tanks like I did, they don't fit!!!!!! Why Toyota changed them that amount I have no idea.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
no my buddy is running a stock 7M radiator on his 1JZ with hydro fans it will work except without the temp sensor in the Radiator yur hydro fans (if thats what yur using) will be at full blast at all times.....
if yur using the 2JZ water pump and mechanical fan then it would be the same thing as a 7M with mechanical fan
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
Im using an 87 7M radiator with my 1jz and hydro fan setup with working hydro fan temp sender. I just drilled and tapped a hole in the bottom for the temp sender and used alot of copper High temp RTV on it and it has been working great with NO leaks for 6000 miles now.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
The fan does not spin at full blast without the temp sensor. It does spin, but that is the slow speed. When the temp sensor is hooked up and the ecu plugged in, that speed of the fan creates a little hurricane. Big difference.
Someone also mentioned on Supraforums that they just used the 7m radiator and just wired a resitor instead of a sensor. ( cut the sensor wire plug and joined the two with a resistor in between.
Drilling and tapping is another good way if it does not leak.
RWHP
Going for 1JZ
Jan 14, 2008
126
Ostersund
Don't know if this is the right thread for this question but what the heck ;)
I want to remove the hydro fan setup, what do i have to do? I will beusing a 7M radiator and a 14" electrical fan instead but i'm worried about the hydro fan setup. Do i have to change to a 2jz waterpump, hope not to!
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
i used a 7M-GE rad on my 7M-GTE set up and it would overheat everytime i drove it. Changed the rad and never had the problem again. So yes, im sure you could use a GE rad, but id bet money on you'll be making another thread asking why your 1J is overheating
RWHP
Going for 1JZ
Jan 14, 2008
126
Ostersund
Ooh my bad, didnt see that this was about the GE rad, i have the GTE rad ;) So no problems then? But now to the hydro fan issue, for me it is anyway :1zhelp:
tissimo
Stock is boring :(
Melbourne, FL
Nope it runs full speed
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
Been using 7mge rad and 2jz pump and fan for over a year and my car never over heats even when drove hard with the ac on during the Fl summer heat...
The Reaper
Jan 10, 2006
1,909
Florida
w00t told you it would work. and this thread is ANCIENT
this was back before i even ORDERED my 1J hahaha
and tissimo is correct it runs at full speed with out the sensor
suprastanger507mgte
Hayward , Ca
You may have to change over to the MkIV H20 housing and pump setup.YOu wouldn't need a fan if you are using the electric ones.
If you are in the us, I will take your hydro fan / shroud setup :)
suprastanger507mgte
Hayward , Ca
Dang these little things are so inconsistant.
Here's how I tested mine on the 2JZ :
NO Senor, no ECU = Slow speed.
NO Sensor , ecu plugged in = Full speed
ECU + Sensor both plugged =l normal desired operation > Fan speed varies according to temperature.
The Reaper
Jan 10, 2006
1,909
Florida
you are correct. don't be so hard on yourself.
we are talking about with the ECU and no sensor. so your chart is right on target! ;)
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
Hey guys, would it be alright just to run a 7mgte rad and 2jz fan by them selfs? without the little stock fans next to the battery?
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
you can but the aux fan helps a bit especially when the ac is on...
RWHP
Going for 1JZ
Jan 14, 2008
126
Ostersund
Okay, so 2JZ waterpump it is with a 14" Summit fan :) Noo sorry, i live in sweden!
