supraman7mgte;1340554 said:apply this tech to a supra
mecevans;1340563 said:holy shit! lithium! now he need a brushless motor:evil2:
7thousandpiecesMGTE;1340885 said:this is the future, has been for some time.....Big Oil has been the only thing in the way.
Pr0ject_Supra;1341100 said:That and this
http://www.youtube.com/watch?v=QJCZ4ayioCU
Lithium + oxygen + a little heat = deathtrap
If it's raining you don't even need the heat. Don't forget it's a chemical fire and lithium + water will fuel itself. With the number of cells needed to run a daily driven car there isn't a very good way to hide them all safely if a wreck occurs.
Pr0ject_Supra;1341929 said:Gasoline needs a spark to ignite. Most wrecks although violent don't create a spark, hence most fender benders don't turn into raging inferno's. All a lithium cell needs is to be cracked. The battery will already be warm from the redox reaction supplying the car with power and a crack will expose the lithium to oxygen and start a CHEMICAL fire. One that cannot be put out with water. In fact search youtube for a lithium water reaction, it's very exothermic.
Current cars do have a battery, same redox reaction concept but different elements being used.
suprarx7nut;1342064 said:Props to fun alternatives to gas. Still doesn't solve the air quality issue since the power required to charge the batteries still generally comes from coal...
Wind energy and solar have great potentials.
Now if only making the batteries didn't cause acid rain and horrible, horrible pollution maybe then I could get fully behind electric cars.
