Technically speaking from years of in depth research and analysis......
the 7m-gte will run like shit with a busted knock sensor. :biglaugh:
bigaaron said:Technically speaking from years of in depth research and analysis......
drjonez said:i beg to differ. i've had several cars that have run just fine whilst throwing code 52.
the real way to find out would be to call up reg and ask him.
jetjock said:Good point, although I wonder why the N/A has the same block and only uses one. Must be that turbo thing![]()
bigaaron said:You must not have had a turbo on it then, or you were not running any boost. :icon_razz
If it is a loose wire it could throw an intermittent code and still work but if the sensor or wire is broken completely it will run like crap, unless of course, it always ran like crap and you just didn't notice. :icon_razz
TCCS said:If the sensor's (referring to the knock sensors) connector is disconnected, while the engine is running under heavy load or maintaining a high speed for a short time (one or two minuts), the CHECK ENGINE lamp lights up, At the same time, the ignition timing is retarted no more than 10 degrees from normal.
This is true. It isn't a common thing, but Toyota is sometimes silent on its systems. And this will sometimes show in the repair manual also.For example in all my Toyota TCCS manuals (which are very comprehensive) nowhere does it mention two trip detection logic for code setting while the aftermarket manuals do. Yet I know from introducing faults on my car that Toyota uses it. (It's also commonly used by other car companies).
Yeah, back to the topic.I understand that if the engine was cranking slowly that the CPS may be causing issues starting, but my problem goes away when the engine is warm, so it doesn't seem to be a cranking speed related problem.
Nick M said:In my experience, drivability problems that go away are one of two things. One is a worn engine, and that is not usually the case. The other is ECT circuit. If your sensor sends a phony signal, the ECU may not run rich enough for the cold temps. A lean condition will cause a miss just as easily as ignition.
jetjock said:Fuel Pressure Up is for hot starts. The CSI is for cold. The car will cold start with no CSI in warm temps but the CSI makes it quicker and really helps when chilly. My car starts with a touch of the key, hot or cold, for example. Toyo didn't stick it in there just to make the car heavier you know. A good battery helps too.
jetjock said:If you smell fuel at least that means you're getting spark (if you didn't have spark the ECU would kill injection soon after cranking) so it's likely a cold enrichment problem. The fuel smell is a symptom of your problem. Reminds me, when you do get it started (when it starts hard) are you holding the pedal to the floor to put the ECU in flooded start mode? Might want to try that until you get the problem fixed.
jetjock said:There isn't much in those vacuum lines that'd keep the engine from starting. Do you hear the ISCV step back on engine shutdown? Is this an N/A or turbo car?
