cams cams cams
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i have notice some thing here on sm
there really is no feed back on the brain cower cams at all in any shape or form in any of the stages
i find this kinda sad really
so i was going to get set of re grind done but now i can't cause i wana rasie the rpm and now i risk spitting shim
so what is the feed back form bc
264
272
280
and then custom spec's that you guys have
SWD Fredester 3
674
baltimore maryland
I have a set of BC 272 cams that I was going to run in my build, they are still in the box on the shelf. After talking to Ian about them I decided not to use those cams. I did buy a set of billet cams from Rich at SIP. Those cams are
9MM and 234 degree duration at .050 lift.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
doesn't cower just do regrinds from the base lobe if so that make your shimm pretty thick
935 offers this but say's it regrind
and nothing is listed on there site
i just don't wana risk spitting shim at 7000 rpm or so
this is what i wanted to run befor 264 and 8.1 mill lift from colt cams
has any one tried this befor ?
gaboonviper85
3,236
Northeast Philly
still worth it...especially if you are doing high rpm pulls! it will benefit the valve train with less weight and more dependable...but its also one reason why im not going with aggressive cams with my motor build as it requires alot more money.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well that drive's up the price to the point were drop in cam are about the same price
i have alot fo oem shims kicking around
now the key here is how thick of shim can you run tell you risk spitting it out ?
gaboonviper85;1238471 said:
why not just invest in shimless buckets and be done with it?
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
Its usually a problem of them being too thin when they kick is it not?
Tun_x
Built to do the NASTY!!
Utah
I run the 280's... I think that when are deciding on cams it is critical to know what your head is capable flowing and at what lift and match the cams accordingly ....
Here I go again with crazy talk
Jason
NashMan
Aug 5, 2005
4,940
17
Victoria BC
280's from who what spec? that really does not help it's like saying you have a car and it drive's and you selling that to some one that wants ot buy a car
Jason
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i was looking into thou cams they seam like shit for low end and will really hurt my brakes
how do you like these cams and what the power band like ect ect
teh more the info the better this thread gets
suprarich
Guest
Nov 9, 2005
2,187
ohio
Nash, if you run a regrind, don't use a thicker shim on top. Place a "make up" shim under the bucket that is the same thickness of the amount of base circle that was removed. Then just continue to use the stock shim on top. A good key to not spit a shim also is to run the cams on the tight side of clearance in respect to lash.
