I've been searching for a way to be rid of my airflow meter since my third one just threw in the towel on me. I've gotten two from the junkyard previously, but after visting several this weekend I was unable to turn up any cressidias or supras that had an AFM on them.
I was poking around the net looking for an alternative or different car to get one from and I stumbled across the aftermarket replacement by cardone ($250... sheesh) and they cross reference their item as being good to use in the following vehicles:
LEXUS
1990 - 1991 ES250
MAZDA
1986 - 1988 RX-7
TOYOTA
1988 - 1991 CAMRY
1986 - 1993 SUPRA
So this made me go out and search for a picture of the camry unit and I found this (engine bay might look funny to you guys, that's because it's in a mk1 mr2):
This is from a V6 (2VZ-FE) Camry. I was wondering if anyone knew about interchangibility between the two? This would give me a slightly larger pool to search from at the junkyard.
Then I looked up the Rx-7 flow meter to see what I could find. Looks similar on the outside and inside and looks to be 7 pin as well!
So my great big question is... does anybody know of alernatives to the AFM (other than maftpro and going with a aftermarket AFM unit)? Cheap and easy are key here
LEXUS
1990 - 1991 ES250
MAZDA
1986 - 1988 RX-7
TOYOTA
1988 - 1991 CAMRY
1986 - 1993 SUPRA
