Cam layout discussion
Doward
4,245
Alachua, FL
7M-fanatic said:
I agree that the .050" is not correct for a cam & bucket style head.
Typically the .050" is used on US pig iron V8s with 100 year old push rod valve train. So much flex, that they had to go to that much lift just to get all the stamped sheetmetal parts to load up.
Which is completely hilarious, because overhead cam predates the pushrod overhead valve configuration by what... 30 years?
7M-fanatic
95
San Antonio, TX
Bull $hit !
You sure don't know much about internal combustion engine history...
(yes, they were around before you, your fatehr, and his father were born)
Maybe you should spend a few hours at a library.
Kids..........
Doward
4,245
Alachua, FL
Jesus, I'm 24, not that old!
Look up the Oldsmobile Rocket V8 - 1949.
During the 30s, the Ford Flathead was 'it' as far as motors go - and it's not an overhead valve configuration. L-head (much like the 401 Buick) side valve configuration.
On the other hand, Fiat started using OHC in 1912. That makes OHC setups oh - 95 years old? I think we'll just call OHC the 100 year old technology ;)
If you want to discuss this, please take it to PM - no sense in letting this topic get off it's course :)
7M-fanatic
95
San Antonio, TX
Why?
Afraid you will get flamed?
You started it..........
1902 Mercedes PRODUCTION car had a Daimler-Maybach pushrod OHV engine.
1904 JAP push rod engine.
This overhead arrangement was subsequently used in automobile and motorcycle internal combustion petrol engines. JAP became a highly successful supplier.
1910 Mercedes PRODUCTION model, 14/30 engine - pushrod, OHV, with exposed rocker arms.
Chevy's first V-8 PRODUCTION engine was released in 1917. The 90-degree overhead-valve design debuted in the D-series, exposed push-rods, rocker arms, and valve springs.
Note:
All these were PRODUCTION automobiles, not some prototype GP engine.
Libraries are such wonderfull establishements.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Some Fiat road cars (typically the sport series) from post WWI used DOHC engines. While these were not high volume in the sense of Ford, they were true production cars sold and licensed for road use.
Doward's statement that OHC predates OHC by 30 years was not correct, but both technologies did exist in the early years. Typically any technology more complex than a Model T sidevalve was relegated to expensive low volume niche cars be it Mercedes, Fiat or anyone else.
Duesenberg's used DOHC engines, hence their speed
most of your really exotic cars used DOHC...
not to mention in the early days of automotives, electric cars where winning at first...
Doward
4,245
Alachua, FL
7M-fanatic said:
Why?
Note:
That's strange - the 1901 Mercedes 35hp engine that is the PREDECESSOR of the 1902 Mercedes 40hp engine, has TWO camshafts -
http://en.wikipedia.org/wiki/Mercedes_35hp
Run by 2 camshafts, gear driven from the flywheel.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
There is no such thing as new technology in cars (mechanicaly wise) most things had been tried in 1 form or another by the 1930's.
Doward
4,245
Alachua, FL
If Wiki is such a horrible source, perhaps someone will be kind enough to post a cutaway of the motor in question?
I don't know about you guys, but when someone just says 'This is how it is' with nothing to back it up, I tend to not give that bit of information much credibility ;)
So let's see some of these old school engines!
Ian, you should have a couple from your teenage years, right? :biglaugh:
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
OK- that is awesome. I was thinking that the future of the valvetrain would have some sort of slide-valve technology, to get rid of the up-down reciprocating mass, but roller valves? Brilliant.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
There has been work on both hydraulic and electric solenoid actuated poppet valves for a long time with the aim to eliminate the cam and completely divorce valve timing from crank position.
which would allow a MUCH broader torque band, as you could program in ANY cam design, and you wouldn't be hindered by slopes, ect...
the issue is simple though, making it reliable...
Doward
4,245
Alachua, FL
As I recall, Mercedes has already implemented camless actuators -
YEP!
2008 Mercedes W204 C-Class. Direct gasoline injection, electronic valve train :)
KDI-EVT :)
