Cam gear - best sound
deranged
1988 Turbo Supra
Jul 15, 2007
51
TN
5 pages of results on searching for "cam" has yielded little to no results for me. My head gasket's gone out, and when I take the head off, I'm gonna put new cams in it. I want something that is effective, as far as power goes, but I also want something that's going to give my car that throaty, mean sound more like you'd hear in a strong v-8. Pretty much everything else in the engine has been replaced (for stronger, better parts), so I might as well change the cams while I'm at it.
So basically, what I'm asking is, What do I need to look for in order to really improve the sound of the car?
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Ron Ramirez tubular manifold, with equal length runners, good luck getting one :biglaugh:
I have this strange feeling that a FFIM and the smoothly routed IC pipes that go along with it will have an effect
A well designed 4" exhaust, no cat, Burns muffler :naughty:
Big cams should definitely help out especially combined with some more head work, larger valves! But probably not as much as a great exhaust system
Just my $0.02 I'm sure everyone has their own opinion on the matter
5
never going to get a throaty V8 mustang style sound out of a turbocharged I6...
especially once you start modding, all you hear is the turbo
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
What you need to do if you want that V8 sound is put in the 1UZ-FE and run ITB's that would sound sweet.
deranged
1988 Turbo Supra
Jul 15, 2007
51
TN
I'm talking about at idle. I know it's not going to roar at 5 grand like any v8. I just want a mean sounding idle.
If you want to upgrade based on sound and go to ebay to upgrade, that's a bad idea. I want to upgrade my cams, and I'm willing to push some bigger bucks to get a more trusted, more durable, and more reliable cam that will not only enhance my performance, but make the car sound great as well.
MKIIINA
Destroyer of Turbos
Plano, TX
good luck trying to find cams. they usually start at about the $800 mark and go from there.
if you want the nice sound run open dp.
deranged
1988 Turbo Supra
Jul 15, 2007
51
TN
cuel said:
Horsepowerfreaks still has Brian Crower stage 2 and 3 cams.
http://www.horsepowerfreaks.com/price/Toyota/Supra_86-92/Brian_Crower/Engine/Cams
You can always get custom regrinds, or hard welded cams as well. There is an excellent thread about cams stickied over on SF.
Exhaust is going to do the most for the sound quality of the car, at idle as well as wide open.
I've got Borla header/downpipe/exhaust and flowmaster exhaust tip (no cat). Good deep sound at all ranges. I think if I change the sound with a bigger cam, it should sound damn good.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Hmmm...I'm thinking the whole idea of a set of cams has little to do with changing the way the motor sounds ;)
