Calling all mk3 guys!!!!
7EMPIRE
175
Raliegh
:1zhelp::1zhelp::1zhelp::1zhelp:OK I HAVE TWO PROBLEMS,first is when my mom bought the car (its hers) it had no dash lights and the climate control wouldnt do anything,so i did some work and found out it was the dimmer switch.so i got rid of that and they worked.so next i started trying to figure out why there was no a/c,heat,or fan cutting on.i found the problem was the blower motor wires were backwards,so i fixed that.now the thing that pisses me off is i have no dash lights any more and the taillights dont work either.i looked at the diagrams and noticed that the dash lights and tails are tied to each other along with a few other things,so please tell me where i should strart trying to find the problem cuz im stumped.
SECOND PROBLEM the car is going threw coolant WAY TO FAST but the oil is perfect,no smoke,and runs perfect.yesterday i noticed the high pressure line on the power steering had a slow leak.the fluid was green so of course i thought bhg but after i saw the PS line leaking green fluid i elimanated the bhg idea.so now im thinking since the water pump is right on top of the PS,maybe its the water pump or the gasket?????please help
:1zhelp:
Toink
66
Raleigh, NC
I'm not to tech savy with the wiring so I can't help you there but have you checked for holes in your coolant system or maybe a small leak?
ians13
537
Jacksonville, fl
Check the 15amp fuse for the dash/tail lights is it blown. If so check for shorts checks all the bulbs, the most common problem is there is a radio dimmer wire that people just leave hanging after an aftermarket radio installation I think it’s like orange or green.
Burning coolant might be BHG, but before you check for that. Does the car run hot? "Take it to a shop have it pressure tested also have the radiator cap tested".
Does it misfire when you start it after it’s been sitting for some time?
7EMPIRE
175
Raliegh
ians13-i dont think it is burning coolant,the car doesnt run hot,and starts perfect,im about to check for the wire
YOUR ONPOINT KNOWLEDGE ARE AWESOME AND PEOPLE LIKE YOU MAKE ME LOVE THIS SITE MORE AND MORE ITS THE REASON I CHECK THIS SITE MORE THAN MY EMAIL!!!!
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
Orange, and there's a negative and a positive. Good idea though. 7EMPIRE, does the above (about the stereo) apply?
7EMPIRE
175
Raliegh
i do have a aftermarket stereo and i checked for the wire and i think i found it it was orange and had a black stripe, but that was not the problem.it turns out it was a fuse FACE PALM.thanks for the help ians13.
7EMPIRE
175
Raliegh
no i havent found the coolant leak, 97percent sure its the water pump. i will check the 90 degree hose tomorrow.and if thats not it im putting in a new water pump friday
