Well, it's update time again. The last time i worked on the car i was about ready to push my skirts through the woodchipper because i couldn't get them to fit and align like i wanted them to. Gladly i calmed down, let the thing sit for a couple of days and then looked at it again.
At first i was going to do what Tekdeus told me before, however, when i rolled the supe out of the garage today it quickly became clear that i overreacted and things weren't nearly as bad as i first thought they were. I really went shutterbuttonhappy today so here are a bunch of pictures
When i took these pics i was thinking **wingless**
Then i was wondering what it'd look like with the Regulus wing on it...
That's when i thought... to hell with wingless
and also when i spotted the supe's reflection in the windows of the neighbors garage/workshop
A little later i realized that it was time to start cleaning that thing up, especially on the inside. Not today however.
And then it was time to actually do something worthwhile besides taking pics for this thread
I had lined up the rear upright section of the skirt with the door and the S2 q-panel and positioned it with some nifty tools. I put a big socket between the extension plate in the wheelwell and the skirts' upright which bent it toward the car.
Then i needed to pull the top of the upright outwards a little. Nifty tool huh ? Yes that's a wheelstud. I have 10 of those... all 15mm longer than stock bolts.... all too short for my liking though
After that i managed to put two layers of woven fiberglass on again. Should look the same as the one on the other side.
While that was curing i was getting bored. Yes bored, even with that much left to do. Then my eye fell on the midsection of the taillights.
I knew it needed a good polishing because it was scratched quite bad, as you can clearly see.
A little elbow grease and some Commandant nr.4 (which is more of a cleaner than anything else) left me with this result....
IT SHINES!!!
Of course i had to put it back on the car and it will probably get scratched and dirty again, but for now... i have
1 shiny part on the exterior of my car....
After a couple of hours, polishing, dinner and pushing the car back into the garage, the resin had finally cured enough for the skirts to be removed. Needs a little sanding methinks...
That's all for tonight. The supe is back in the garage and hopefully i'll be able to do a little more work on it tomorrow and friday.
