Is there anyway to disable or bypass the stock alarm. This 87 i just picked up, when I unlock it with the key from either door the alarm will go off and I can't start it.
this is in the informative links sticky at the top of the 7m tech section.
edit: isnms- isn't it odd that we both posted pretty much the same info on the same day on two different forums. (albeit, you're a bit quicker than me)
