I'm considering purchasing a rebuilt engine from www.motortime.biz, who is a seller on ebay (motortimeusa). For $2000 I get the following, plus MHG and ARP studs. What are your opinions?
List of machining processes performed
- Engine and head cleaned
- Surfaces renewed by milling
- Blocks bored and honed
- Connecting Rods reconditioned
- New pin bushings installed
- Crank shaft ground and polished
- Cylinder heads pressure tested
- Cam lines checked
- Heads checked for thickness
- 3-Angel valve grind
List of new master rebuild kit parts installed
- New pistons
- New piston rings
- New rod bearings
- New main bearings
- New wrist pin bushings
- New oil pump
- New thrust bearings
- New head bolts
- New rear main seal
- New valve guides
- New valve seals
- New frost plugs
- New lifters.
There are pics on the ebay listing.
http://cgi.ebay.com/ebaymotors/Rebu...18&_trksid=p3911.c0.m14&timeout=1218485776921
Thanks.
Ben
- Cam lines checked
- New pistons
- New piston rings
- New rod bearings
- New main bearings
- New oil pump
- New head bolts
- New valve guides
- New valve seals
- New frost plugs
- New lifters.
Thanks.
Ben
