buying a 1jz mkiii
terror
Antibliss
Jun 13, 2008
242
Alaska
Ive been looking to buy a supra for some time now, i was focused on getting a 7m but i came across a 89 1jz swaped mkiii and before buying i wanted to know if you guys had any tips on buying a supra with a 1jz, is it much different than the 7m and how are the hks sport twin turbos. thanks alot.
1jzSpecial
25
South Florida
1jz is much stronger and rev happy:icon_bigg 7500-8000 , the engine is known as a bullet "proof engine" because of it ability to make massive amounts of power (700whp more or less) on an internally stock long block.
7m cannot hold that amount of power with out upgrading the internals.
terror
Antibliss
Jun 13, 2008
242
Alaska
that doesnt give me any tips on what to look for when buying a 1jz supra
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
The rules of buying a supra / 1JZ is the same as it would be for buying one with a 7mgte.
Look at the quality of work, especially wiring harness.
Look at the engine bay and check for leaks etc.
You can check the exhaust in the back for excessive blow by - this will tell you if the turbos are blown or on its way out.
Drive the car and see how it runs and boosts.
Check the gauges when you drive it to make sure everything is working in order.
Does the 1JZ engine meet your state's emissions requirements?
terror
Antibliss
Jun 13, 2008
242
Alaska
i know a few people that will smog me no problems. is th 1jz just as prone to BHG's as the 7m?
ma70mkiii
139
ohio
i believe the 1jz has a metal head gasket vs. a cosmetic gasket on the 7m. the 1jz's overall potential is so much greater and when a lil honda or eclipse thinks he is gonna spank ya he better think again unless he got a ton dumped under the hood. get a bigger intercooler and unchoke the factory crap and get a nice exhaust, a boost controller and afpr and maybe some electronics depending on how bad u want to kill ur victim. me im goin single and getting some 550cc injectors and i have a 28x11x3 intercooler and getting a hks ssqv bov and run about 16psi and u can easily make 500hp. 7m's have poor head work vs. a jz motor. the 1jz would be in ur best interest. if the car is in good condition and motor runs smooth to power band and has no leaks i would go for it. how much does he want for it and does it have and upgrades or is it all factory? those are the questions u need to ask urself. the parts needed to do a jz swap so far im up to about $8k so go from there.
1jzSpecial
25
South Florida
LOL I had a civic Hatch pull up on me with a built motor and I gave it good spanking:icon_bigg
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
It is also wrong.
Don't turn this into a 7M bashing thread guys...
My first concern would be the quality of the wiring. If it looks Micky mouse, walk away.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
1JZ's are not prone to blowing head gaskets. It isnt the HG that is bad in the 7m, it is the factory torque specs that cause the BHG. 7m's are excellent motors, as long as the HG was done right! by getting the block and head machined, making sure it isnt warped, using a MHG with arp studs and a 7m is basically as good of an engine as a 1JZ. just not as re-defined...
1jzSpecial
25
South Florida
I Couldn't of said it any better
