I bought a used one with the lexus aluminum and put the lexus electronic black box right on my stock supra housing for the time being. Haven't seen the code or a problem with it since. I don't think they wear out but they are real sensitive to dirt dust and especially oil.
I took the dead one apart to see if there was any salvaging. You can't. It's hard core glued together. The photo LED's are glued into the holes. The metal which is springy and really thin is 1/4" wide and the hole that the LED's see through is 1/8" wide. Its sealed between two pieces of similiar silver metal that is hard and snaps like a one sided razor blade metal. You can't really get in there to clean it because the space between the 2 pieces of metal could maybe squeeze a piece of paper in there.
It's really perfect as a sealed non serviceable part. Here's some pics using a hammer to disassemble
The first pic illustrated the black glue used. Feels like silicone gasket stuff.
The second pic is the actual metal that wobbles back and forth. Image taken on the black part of a CD case to make it stand out better.
The third pic shows the window for the LED to see the reflection - yellow thing on top is a pencil.
