Burning Oil
MrTristoe
California
My car burns quite abit of oil in between oil changes, and im getting too much pressure somewhere which is causing my dipstick to get pushed out frequently. some one told me it could be the pcv valve. how could i test that and what else could cause a problem like that.
AJ'S 88NA
2,419
Florida
Don't really have a valve, check inside the throttle body for oil. You have to pull the valve covers and clean the pvc outlets.
Smoke coming out the tailpipe? If it's pushing out the dipstick you probably have too much blowby.
Check to make sure that the port on the throttle body that goes to the valve covers is clear by spraying some brake cleaner through it.
MrTristoe
California
i know im late on replying but ive done a compression test on the car and compression is good. it was all within 10 psi of each cylinder, alsoive checked the pcv valve and replaced valve cover gaskets, went with a heavier weight oil, and im still having the problem. no smoke from the oil cap. im starting to run out of ideas of what it could be...
