Bumper Fitment
thesupragod
183
Mount Vernon, Ohio
No sweat. Many of the pre 89's here have done this to 'update' the styling. EVERYTHING (with a few exceptions) from an 89+ will bolt right onto a pre 89 supra. Exceptions being the 3 piece wing, and wiring changes.
fox74
SLC
If this is true then I was wondering why the front lip for 89+ does not fit pre 89 ?
suprajim54
119
Dallas, Texas
While both will mount to any 86-92 body, Pre 89 and 89+ are two different bumpers. The lips mounts to the bumper. Therefore, the lips are different. The lips are not interchangeable between the two bumpers without some type of modification/customization.
fox74
SLC
Jim54, thanks for reply, I really like one of the Shineautoproject front lip MA70-Fl-H, but it listed as for 89+. I always thought there is a problem with dimensions, but from what I understand from you reply it is a mounting issue. Would you be more specific about what need to be modified, if it is do able I will make it happen. thank you
#04
526
Cambridge
The lower edge of the bumper is a different shape. And the pre 89 bumper (if traced out) would have a shorter line.
Just look at the 2 bumpers and you can see the 'jaw line' if you will, where the pre89 tapers in and the post 89 just kinda looks bloated.
Also pretty sure the nose panel has holes in different places for the post 89 nose/grills.
