1.... About how hard should the valve springs be...? Pushing down with my palm onto the valve springs onto a bathroom scale, it's taking about 70 lbs to compress the stock springs. Does this sound right?
2. Anyone have pics of combustion chamber work that they or a machine shop has done(IE deburring)? I need to get an idea of what I can work on while I'm doing my head.
3 Anyone else priced valve stem seals from toyota...? Are they SUPPOSED to cost $175 for a set?
4 Should I get my head surfaced if I had it done 20k miles ago and the surface is still smooth with the exception of the ring a cometic leaves in the head? is that ring ok?
5. I kind of tried to do a hardness test on the head, dropping a plastic ball down a 6 inch length tube onto the head. The ball is bouncing up about 2.5 inches off the head the first bounce and about an inch the second bounce. Does this sound normal or does anyone have more information on this kind of test?
