Budget Intercooler Sprayer...
Black Cat
62
Fort Bragg NC
Just remember what ever you do spray, has a good chance of getting sucked in your intake.
So if you spray n2o you will see a increse in power but for the most part its because your fogging your intake with n2o, same with co2 but instead of gaining power you will lose some.
This web site has a good write up on this fact.
http://cryofuzion.com/spraybar.htm
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Given the layout of our intake and the wall between the headlight areas and the intercooler unless you're missing the undercovers I think you'd see very little of whatever you're spraying end up in the intake. Now if your filter is in the engine bay... well, you've already lost enough power, why not give up a little more? :icon_razz
It's still pointless (look at the dyno differences). Soak the sucker down with the CO2 or nitrous before/after a run to combat heatsoak.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Rubbing alcohol is still cheaper than both nitrous and co2.
$.99 for a cheap spray bottle
$2.79 for a 32oz bottle of rubbing alcohol.
Do not soak the intercooler, just give it a quick spritz, the intake mani and IC pipes will also benefit from the same treatment.
Fire risk dude......
The risk far outweighs any benefit.
Do you tune for the chilled temps or for the more normal temps?
It will have to be a compromise tune.
Do you have any way of introducing AIT based compensations?
If so can chill an IC and see some benefit.
