I have a broken flywheel bolt stuck in side the crank and it is broken flush meaning a clean break.... Is there a drill bit anyone recommends
RedEj8 said:Well theyre torqued that much but all that torque is released where theres no head on the bolt. Try a big easy out, or if you have a dremel with a disc, try to cut a groove in it and use a flathead screwdriver to get it out.
