That just might be your motor's sweet spot
As I said earlier this is why degreeing is so important to establish a 0 point
IJ. said:
amichie said:When you find the 50thou lift points do you have to subtract the tappet clearance??
So if your tappet clearance is 8 thou should you degree it at 42 thou valve lift or 50 thou valve lift??
IJ. said:TS: I do mine before I fit the balancer so the wheel bolts hard up against the Crank snout.
IJ. said:TS: Yep just machined a step on the back of the Bolt so the wheel centres perfectly bolt it down then line the pointer up to true TDC 0 and it's good to go
The bigger diameter the wheel the easier it is to read accurately.
IJ. said:Steve: Correct it's just a pilot, from memory about 1mm the wheel I have is 3mm.
