Brakes, Rotors, Calipers, ETC
TomFraser
My supra needs a new brakes setup.
I don't want or need extreme performance, preferably just a little better than stock.
I also don't want to spend too much cash, don't care about buying used and stuff
does anyone have recommendations for brakes the same as stock or a little better with about what I would pay for them?
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Get some Brembo blank rotors and Porterfield R4S pads. Only get new calipers if you need them. If you want even better performance, get stainless steel brake lines.
bbk or stock. i really dont see much of a difference with are small stock rotors and pads versus upgraded pads and brembo blanks. i have run both brembo blanks and trd ceramic pads and stock with stock pads all feels about the same. if your going for performance go with a bbk period. people spend more money on upgraded pads but your still using the same small shitty brake system. upgraded or dont waste your money.
brembo blanks or not your still running stock size rotors wiht upgraded pads or stock with stock calipers. bigger rotors, upgraded pads, and upgraded calipers with duel piston or quad pistons then you have more mass with more clamping force and you will get better braking force.
brembo blanks are wat 50 bux each cheap and cheaper than toyota prolly.
