Brakes question
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
I dont know a whole lot about brakes but i noticed if i push and release the pedal several times while in motion, pumping it, it gets progressively harder to slow the car, and the pedal stiffens up more and more. i didn't do it for a long time, just a few pumps, less than 6.
i just wanted to check to see if this is normal....
thanks. lol....
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
Its normal.
Supras use a vaccuum assisted brake, each time you use the brake you use a little bit of that vaccuum pressure.
It shouldnt get noticeably harder while your engines running though, maybe if you pump the pedal fast.
It draws the air/pressure from the rubber hose that runs from the brake booster to the intake manifold. Theres a one way check valve inside, try blowing through both ways and see what happens, air should only go through towards the booster if I know what Im talking about.
Figit090
Jan 7, 2006
1,835
Humboldt County
yeah i pumped it quickly. after a few seconds it was back to basically normal again. i might check the airflow later if i get a chance.
Figit090
Jan 7, 2006
1,835
Humboldt County
nope, no ABS. i was just goofing around BTW. wanted to see what it would do i suppose...not really sure why. i think i was riding the brakes to get them to stop squealing and after a few depressions it felt a little funny so i pumped it more rapidly and noticed that...
hard to remember though....
