So you ask about "unused rotor" and then you illustrate the exact point I was attempting to make. In other words, the stock brakes already have enough torque to overpower the tires. So the main reasons for a bbk are heat dissipation for repeated stops and decreasing some effort by moving the torque arm out away from the center of the hub.
Is it good to lock the tires up, no that's not what I'm saying. However, locking 200 tread wear 255s with ease is something of a feat honestly. The car stops on a dime with that swept area and has plenty of room for good modulation.
I also don't have ABS currently, hence that example.
If you increased the pad swept area (decreased the area of unused rotor), you could lock the tires easier initially, but as we've both pointed out now that is not ideal (less modulation and pointless). It would also potentially increase heat leading to fade and degradation, which is the opposite of what you want. The caliper and pad are to be ideally cooled as quickly as possible within reason, thus it is all well that it does not have a larger friction surface provided it already does its job just fine.
A related item are folks that think they need a massive rotor too. You want the lightest/smallest rotor that can get the job done because that means less rotational mass. Throwing a 14"x 1.5" rotor on a car that never sees the track or a beating of the brakes is sort of well, a waste.
