Well i am just trying to figure this out,
Latley when i go to step on my brakes after the system is cold, my pedal is hard to push and becomes like a rock really fast, I do not have normal braking ability and if i push any harder the brakes lock up and the ABS kicks in which in turn actually has been making my stopping distances even further.
1. When cold the brake pedal is hard to push can not be pushed far and wheels lock up upon trying to apply more break pressure.
2. Once warm, pedal play feels more normal and brakes begin to function a little more like what you would expect.
3. Once nice and heated up brakes seem to work fine, even better and the brakes work like a champ.
The system
EBC Green stuff Pads on the front, Some Normal Pads on the Rear. SS braided lines on the front. Brembro Replacement rotors that have been cross drilled (i know)
I have some Motul RBF600 non Silicone based Brake Fluid. Right out of the bottle though it looks like old Brake fluid
it is very dark in colour fresh from a newly opened bottle.
I have no idea what going on with my brake but definitely need some help and suggestions
Update July 3rd
Changed the Booster and Master today and Bled the Master and all the Lines. The Brake Pedal is still hard on first Push almost rock hard and still no braking power, if i push it again right away just after letting go, then the brakes will work on the second of third Try?????
Please HELP!
The system
Update July 3rd
Please HELP!
