brake problem...
rayall01
901
Westfield, ma
IJ.;1376910 said:
You have an issue with vacuum bleeding yet you're advocating breaking the flare nuts loose?
WTF... :nono:
enough dude
Done it myself, and it's worked. Unless I say it's an opinion, or an idea, it's something I've actually done, and had it work. I wouldn't say it if it didn't work for me, and other mechanics I've worked with. I've bled brakes from flare nuts, and banjo bolts, and never had a problem.
gofastgeorge
944
Texas
IJ.;1376908 said:
I did this shit for a living as a kid so actually have a clue.
I'm fast getting to the "don't give a fuck" point and just won't bother correcting anymore of the misinformation and bullshit here and it can turn into a fucking joke like Supra Forums.
Don't let the 'King of Misinformation' get to you.
Pretty sone he will kill his supra, part it out, and be gone.........
bobpogoman
213
Quebec, Canada
ok guyes please stay with my problem :S
even if there could be any leaks and air going back in the system even if im @ 20vac with my bleeder, actually i cant even get a drop of oil out of the bleeder!
like if something was blocking the lines,
ive been up to the source and noticed the oil in mc reservois wont even enter the mc....
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
you cant get a drop out of ANY of your lines??
do you feel pressure when you pump the brakes? you leave your car running right?
bobpogoman
213
Quebec, Canada
i must let the car run to do it?
i tried both rear lines, nothing come out, as i said with a hose from bleeder to a jar of oil, when i press the pedal i dont see any bubbles in the jar. there was only bubbles the 1st time i did it when i bench bleeded the mc, since there was oil in it, i pumped brakes and when i crack loosed the hose some oil squirted out, then if i do it again theres no more.
i havnt tried the bubble stuff from rear right since bleeder is broke,but as the rr one, there was only a squirt the 1st pump after, nothing.
exactly if the master wasnt getting oil from the resevoir. it push its oil out then dont get any more.
bobpogoman
213
Quebec, Canada
heres an update, ive gone to autoparts store, got another freshly rebuilt master cylinder.
i can bleed the front brake easy, the oil come out a lot, for the rear brakes, nothing,niet, i cant bleed them. why?
its the kind of valve close to the mc ?? or its the abs unit?
rayall01
901
Westfield, ma
You are supposed to bleed in the correct order. Right rear, left rear, right front, left front. Also, if the lines are empty, it will take some time for fluid to reach the rear. That's quite a distance for the fluid to travel.
bobpogoman
213
Quebec, Canada
ya i know the order, sorry didnt said it, both rears were not working so i tryed the front ones, and they worked, thats why i started with front.
i bleeded over 15mins the rear ones, theres no air, nothing coming out of both, and the lines arent empty.
Unscrew the rear lines at the ABS open both rear bleeders and use a piece of hose and blow the lines out with a compressor, then if nothing comes out carefully inspect the rear line to see if it's been squashed flat (first place to look is down by the rear subframe mount)
